Protocol RIB Abstraction Layer has allocated a set of operational damping parameters.
No action required - Informational message only.
Debug-Summary
The Protocol RIB Abstraction Layer has allocated a set of operational damping parameters. VR = %p1% Penalty cutoff threshold = %p2% Penalty reuse threshold = %p3% Max route suppression time = %p4% Available route penalty half-life = %p5% Withdrawn route penalty half-life = %p6% Available route max penalty time = %p7% Withdrawn route max penalty time = %p8% Size of available routes penalty factor array = %p9% Size of withdrawn routes penalty factor array = %p10% Scale factor: integer part = %p11% Scale factor: fractional part = %p12%/65536 Max reuse index = %p13%
| Name | Type |
| p1 | uInt32 |
| p2 | uInt32 |
| p3 | uInt32 |
| p4 | uInt32 |
| p5 | uInt32 |
| p6 | uInt32 |
| p7 | uInt32 |
| p8 | uInt32 |
| p9 | uInt16 |
| p10 | uInt16 |
| p11 | uInt16 |
| p12 | uInt16 |
| p13 | uInt16 |
